4
This discussion topic has been answered Discussion topic: Sky Signiture
This message was authored by: Jason1029
Sky Signiture
Recording says upgrade subscription
Re: Sky Signiture
@Jason1029 wrote:
Sky Q. I have the signiture package and can watch the Atlantic channel. I have recorded ( and watched) 3 episodes of a series but the recording of episode 4 it's saying upgrade the package.
Hi @Jason1029
First check that you are not trying to Download or view HD or UHD content without the Q HD or UHD Subscription pack.
The Sky Q Sports pack and BT Sport if you subscribe through Sky are in HD as Standard.
Sky Cinema if you subscribe is also in HD.
Sky Signature includes BoxSets and Entertainment channels only in SD as standard.
Only free to air channels such as BBC, ITV etc are in HD. The Q HD pack is required for all other Sky Signature HD content, including Catch Up in HD, On Demand in HD and BoxSets in HD
If you do not have the Optional HD pack you need to change the Download to SD in All Formats (as HD is the default setting).
So that you do not need to do this every time it’s best to change your Download preference to SD in Home - Settings - Setup - Preferences.
This needs to be done on the main Q box.
Then if you want to download any HD content from free to air channels (BBCHD ,ITVHD etc) you can select HD in the All formats tab of the content . This will change the format for that particular download only but still leave your format to SD in preferences.
Re: Sky Signiture
@Jason1029
On what device are you trying to watch this recording ?
Avatar for Jason1029
Re: Sky Signiture
Re: Sky Signiture
Hi @Jason1029
Re: Sky Signiture
Thank you so much, this has worked.
