Discussion topic: Sky Qbox signal problem
This message was authored by: Mort5
When we switch sky on we are met wjth the following prompt:
It looks like you do not have internet connection right now. If youre already set up we will keep trying to connect.
Tried several different promts through settings and nothing has worked. Now the second Qbox isnt working at all and no sky channels are accessed through this box.
Issue now been going on 10 days. nothimng wormg with internet as all other devices such as Xboxes, laptops etc all workimg fine
Re: Sky Qbox signal problem
Hi @Mort5
Have you tried a Network reset on your main Q box?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
