Discussion topic: Sky Qbox keeps crashing
Message posted on 22 Nov 2024 09:29 PM
Over the past two months, my SkyQ box is crashing on a regular basis (getting worse)-
- Box won't come out of standby
- Box crashes when recording more than one program - no particular station
- Sky mini boxes lose connection
- I have disconnected the ethernet cable and switched back to Wifi - same issue!
- I have rebooted the router
- The SkyQ box is at least 4 years old
- Software version - Q270.000.10.02L
- UI version - 27.772.271.00
- Hardware version - 32B206
- Network Version 2.0
Any idea on how to resolve this issue?
Message posted on 22 Nov 2024 09:42 PM
Re: Sky Qbox keeps crashing
Hi @dubirl
Message posted on 22 Nov 2024 09:54 PM
Thanks, oldfella - I'll try resetting the box tomorrow and will post an update once completed.
