Discussion topic: Sky Q
Message posted on 03 Jun 2024 09:32 PM
Sky Q
My sky Q mini box keeps losing connection to main box.
When the mini box is on the main box loses it's network connection.
We then can't watch any on catch up or Netflix on main box.
If I power off the mini box, the main box works fine, anyone else had this issue.
Message posted on 03 Jun 2024 09:39 PM
Re: Sky Q
Hi @AvtarS
Reboot the mini as above.
Message posted on 04 Jun 2024 06:22 PM
Re: Sky Q
Hi, thanks for the info, I have done this several times, after a week or so the main box loses connection to router and have to go through the same process.
This started happening about4 -5 weeks ago.
Message posted on 04 Jun 2024 09:02 PM - last edited: 04 Jun 2024 09:02 PM
Re: Sky Q
Hi @AvtarS
Try a Reset Settings in the main Q box hidden menu.
