This discussion topic has been answered Discussion topic: Sky Q won’t work at 4am
Message posted on 08 Aug 2023 05:55 PM
Hi, sky q main box and all the other boxes won't work at 4am. Says not connected. Works fine at 6am. Why? Thank you.
Message posted on 08 Aug 2023 06:02 PM
Your box is probably set to Eco Standby mode, this puts the box into a low power mode between 2:45-5:45am. You can change it in the settings:
Go to Settings, Setup, Preferences, then set the standby mode to either Active or None.
Message posted on 08 Aug 2023 06:03 PM
Re: Sky Q won’t work at 4am
Message posted on 08 Aug 2023 06:13 PM
Thank you!!
Thank you.
