Discussion topic: Sky Q wifi connection
Message posted on 23 Aug 2024 11:24 AM
Sky Q box (about 4 years old hardware version 32B108)
Connection to Google wifi, broadband speed appx 72mb/19mb
Streaming has become next to impossible on all platforms inc iPlayer, Apple TV+, Amazon etc. Freezes, gets to 1% and halts or simply says connection error.
Use the smart TV interface instead no problems at all. Slick and quick.
Got 2 Sky Mini boxes around the house and no problem usings streaming services on them.
Can it be the box?
Message posted on 23 Aug 2024 11:53 AM
Re: Sky Q wifi connection
Can it be the box?
Hi @ChrisNewman
Try a Reset Settings in the main Q box hidden menu.
