Discussion topic: Sky Q to Freesat
This message was authored by: Torque
Sky Q to Freesat
Guys
Trying to set up a Freesat 4k box to replace my sky q box which ends soon.
Plugging the 2 sat cables over its telling me no signal detected.
Any ideas please ??
Re: Sky Q to Freesat
@Torque wrote:
Guys
Any ideas please ??
hi @Torque
the Freesat 4K boxes can be a little temperamental at first with the wideband LNBs that SKY Q uses
Please see some steps that our kind user here - @Godfrey  - has found that seem to work for most people
Freesat4K steps
Avatar for Torque
Thanks. I will give it a go.
I had read that you may have to leave it overnight to receive a signal. Is this correct ?
Are Freesat aware of this ? No mention on their site, and of course its Saturday so cant ring them.
@Torque
I think the overnight  element that we used to mention is the part mentioned in the steps regarding 30 minutes so probably the 30 mins or so maybe all that is necessary.
I have no idea whether Freesat are aware.
Avatar for Torque
Ill leave it switched on for a couple of hours then stby/on and see if it sorts it.
In settings it sees the LNB etc but when i do a Chan scan it says no signal.
Thanks for your help.
This message was authored by: Godfrey
@Torque   This is where I found the advice that I posted;
Freesat box initially cannot find Wideband LNB signals
Godfrey.
Avatar for Torque
Thanks.
Looking in settings my software version is v.1.4.3 which is old so it looks like it needs an update to v1.5.0 or later.
Avatar for Torque
Thanks guys. Once i had managed to force the box to do a software update all is fine.
Pity Freesat dont ship these with uptodate software. Mine was updated last in Feb 22 !
Thanks again.
