Discussion topic: Sky Q saying it has no Internet connection
This message was authored by: Paul249
My Sky Q box is giving me the following message: It looks like you do not have Internet connection right now. If you're already set-up we'll keep trying to connect. If you have changed your Internet password or eouter you need to reconnect to your network. Go to settings and check your network connection status to reset. Internet is working fine on all orher devices in the home. Has been like this since yesterday I have tried resetting but says it can't find a connection. Any help appreciated.
This message was authored by: ThePope27
Re: Sky Q saying it has no Internet connection
Hi @Paul249
Do you have Sky Broadband?
To initiate a Network Reset, navigate to Q box Home > Settings > Setup > Network. Once there, highlight "Status" and then choose "Reset" from the options on the right-hand side. Follow the provided instructions to establish a WiFi connection with your router.
If you're using Sky broadband, you'll be prompted to press the WPS button on the Sky router. Remember to press the WPS button on the Sky router itself and not the reset button on the Q box, as the Network reset will automatically trigger the WPS process on the main Q box.
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
