Discussion topic: Sky Q remote 😱
This message was authored by: ray+blundell
Sky Q remote 😱
Does anyone else think that the Sky Q remote is terribly designed ? Semi circular underneath and rolls around when you're trying to use it, unless you pick it up. 😱
Re: Sky Q remote 😱
Hi @ray+blundell   You are several years late to the party, when it comes to the design of the remote.
Re: Sky Q remote 😱
I suspect it's designed to be picked up.
Re: Sky Q remote 😱
Yeah I just pick it up
it has other flaws too. It's not great.
