4
This discussion topic has been answered Discussion topic: Sky Q remote will not pair with box
This message was authored by: RJB4
Remote will not pair with box. I've tried all self help and got a new remote. Box otherwise works fine.
This message was authored by: nigea99 Answer
Re: Sky Q remote will not pair with box
hi @RJB4
As you say the box otherwise works fine, does that mean that you can control the box with the remote ?
If so is this only in Infrared mode or can you use in bluetooth mode (which allows Voice control)  ?
If you can use Voice control then it is paired in bluetooth mode but possibly not for using with your TV
hi @RJB4
Avatar for RJB4
Level 0 icon
I can work the box through the sky app on my iPhone. Doesn't control volume,
Avatar for RJB4
Level 0 icon
The sky remote, now a brand new one,  looks to work fine, but doesn't have any operability of the sky q box at all.
Ah OK
Have you done a full power down restart (unplug or switch off at mains) of your Q box ?
I know you say you have done  all the self help but I will post what you have probably tried but stress a couple of the key points
For the  reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared (You may need to make sure the IR receiver on the box is not blocked in any way)
