Discussion topic: Sky Q remote voice control not working
This message was authored by: Mtoracle1
Hi all
first time asking for help, my Sky Q remote voice control has recently stopped working properly. When I now ask it for the Prime App it goes to BBC London ?
any suggestions?
Re: Sky Q remote voice control not working
@Mtoracle1 wrote:
Hi all
any suggestions?
Hi @Mtoracle1
Wait until the router is completely back and running and then try completly resetting your Bluetooth remote.
Avatar for Mtoracle1
Thanks I've tried this and hasn't worked.
This message was authored by: captcostalot
Try saying amazon prime video not just prime or prime tv it seems not to recognise short commands also paramount is now paramount plus
