Discussion topic: Sky Q remote keeps disconnecting from box
This message was authored by: basilfaulty
A few months ago the batteries in the remote started to lose power and there was a reminder on the screen to change them. Eventually the batteries failed and when I put in the new ones I had to pair the remote control with the box. Since then there have been no messages about failing batteries (not that I expected there would be as new batteries usually last quite a long time) but now at least once a week in the morning I find the remote control needs to be paired again and this has never happened before. Has anyone else had this minor problem?
Re: Sky Q remote keeps disconnecting from box
Hi @basilfaulty
