Discussion topic: Sky Q recording
Message posted on 26 Jun 2023 08:40 PM
Sky Q recording
Hi
when I go to watch my recordings it is saying technical fault,
the programmes are in my scheduled button but then not recording, I have rebooted my broadband and tv and sky Q box
Message posted on 26 Jun 2023 08:45 PM
Re: Sky Q recording
@Mids1888 wrote:
Hi
Hi @Mids1888
