Discussion topic: Sky Q pulling left
This message was authored by Boxerman This message was authored by: Boxerman
Sky Q pulling left
  • For the past hour if I press right on the Sky Q remote it instantly moves back to the left in every menu and TV guide, so I tried removing the batteries and controlling with the app but it still keeps happening, I also restarted the box but it's still basically unusable.
Re: Sky Q pulling left
Hi @Boxerman
Boxerman
Tried it, but after entering 0 0 1 select it moves right into a submenu then instantly goes back left without chance to select any option.
Hi @Boxerman
Try the Recovery procedure in the following link.
This will update the Software which may help.
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
