Discussion topic: Sky Q over CAT 6
This message was authored by: Swoods88
Sky Q over CAT 6
Hi everyone. Has anyone had any luck with transmitting Sky Q in UHD over CAT 6.
Using Orei 1x2 extender (UHD12-EX115K) and works great at 1080p. Whenever I try to change to 2160 it looks like the image attached. Is this due to the 2160/50hz that Sky Q is locked to? Would seem that the extender supports 4k30 and 4k60. Does that mean 4k50 isn't going to work?
Decent CAT 6 cables installed - the photos taken are with a short patch lead so not related to the cable. Any help or advice appreciated.
Thanks!
Re: Sky Q over CAT 6
How long is the CAT6?
For testing purposes, you can get 2150/60 out of a Q box in the apps if you play US content and have the refresh rate option set. (It doesn't support 24, just uses 60 so quite useful for this)
Avatar for Swoods88
Thanks - I will try using an app to check (if I can navigate to it!).
sorry - thought I had added - this photo/test was literally with just a brand new CAT 6 0.5m patch cable so nothing of concern in the length of cable.
