Discussion topic: Sky Q on a sky glass tv problems
Message posted on 20 Jan 2024 08:00 AM
Recently went back to sky Q from sky glass so we are using the sky glass tv. The problems I'm having are I can not pair my remote as it keeps trying to connect to sky glass, I can't use the speak option and every time I change channels I get a information banner along the bottom of the screen telling me what's on tv. Is there anyway I can "turn these off"
Message posted on 20 Jan 2024 11:01 AM
Re: Sky Q on a sky glass tv problems
Try completly resetting your Q Bluetooth remote.
