Discussion topic: Sky Q not working
Message posted on 06 Jul 2023 12:10 PM
Sky Q not working
Hi,
We hav had issues for most of the times with either Q box or the remotes. Somehow we have managed to reset them and get them working.
This week im afraid none of them are working, tried everything possible and still no luck.I have emailed Sky about it and no reply, tried to call with no joy...any help would be appreciated
Message posted on 06 Jul 2023 12:16 PM
Re: Sky Q not working
@MHR11 wrote:
Hi,
Hi @MHR11
First try rebooting your Q box as follows.
If you had to use the button on the front of the Q box to turn it on:
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
You mentioned remotes in the plural.
You can only pair one Bluetooth remote at a time to a Q box.
You can also use infrared remotes with any Q box.
Infrared remotes do not pair to the Q box only the TV.
Message posted on 06 Jul 2023 12:45 PM
@MHR11 wrote:Hi,
@MHR11 Also note that Sky do not use email as a method of communicating with them so unfortunately you won't get any reply to any emails.
Sky Q 1TB UHD
LG TV
Sky Mobile
