Discussion topic: Sky Q not connecting
This message was authored by: Chinwe
My sky Q is not connecting to my TV and it is showing “Not Programmed”
Re: Sky Q not connecting
Try selecting the correct input on the TV?
@Chinwe that sounds more like a message from your TV in regards to your freeview receiver as @PandJ2020 suggest you will need to change to the correct HDMI source to get Sky Q working normally HDMI 1 but could be any of the HDMI ports so best to try all of them
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
