Discussion topic: Sky Q not connecting to internet and mini box frozen
Message posted on 29 Dec 2025 07:55 PM
My Sky Q box lost internet connection on Christmas night and my mini box is also frozen. I've tried all the usual reset advice and nothing seems to work. My Internet is working fine as smart TV still works etc can anyone advise as I'm so frustrated with it now.
Message posted on 29 Dec 2025 09:06 PM
Re: Sky Q not connecting to internet and mini box frozen
Hi @mully2412
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
