Discussion topic: Sky Q - no apps
Message posted on 13 Jun 2025 04:26 PM
Sky Q - no apps
My Sky Q didn't have any signal earlier. Now that I've restarted it and let it sit for a while it now doesn't have any apps on it such as Netflix, ITV X etc which I pay subscriptions for, it says I need to upgrade my subscription ?
Message posted on 13 Jun 2025 04:51 PM
Re: Sky Q - no apps
Hi @Martha10
Have you tried rebooting your Q box?
If that doesn't fix it try refreshing the Apps in the Hidden menu.
Select Apps
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
