Discussion topic: Sky Q new
This message was authored by: Our+Glen
Sky Q new
Hi, had myskyq installed today,I've turned it off for tonight on the remote...its still green light...do I just leave it? Thank you
Re: Sky Q new
Hi @Our+Glen
If the led on the right of the Q box is still green then it is still on.
The led is also the standby button. Press the green led and it should go off and turn amber.
Re: Sky Q new
You've turned the TV off but not the Sky Q box. Short press of the on/off button should turn off the Sky Q box, long press of the same button should turn off the TV.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Re: Sky Q new
Hi @oj01
Assuming it is on the latest software, turning off the TV also turns off the Q box.
I suppose @Our+Glen   may not be aware of this and after turning off the TV gave a short press on the Q remote.  This would turn the Q box back on again.
