Discussion topic: Sky Q network connection
This message was authored by: Neilmat2
I'm getting this message "it looks like you do not have internet connection right now", try restarting your router and Sky Q box. You can also try resetting the network settings on your Sky Q box and follow the on-screen instructions to reconnect to your WiFi"
reset the router countless times, but loses connection again within minutes. Booked an engineer to visit but they can't come for four weeks! Which is frankly unbelievable .
 Has anyone a fix for this please,?
This message was authored by: TonyG5
Re: Sky Q network connection
Sorry to hear about your connection difficulties. Could you supply some more information:
  • Has this always happened, or have you changed your setup?
  • What home hub/router are you using?
  • Do you have any mini boxes?
Avatar for Neilmat2
Hi,
it's only just started to happen.
i have a sky router and three mini boxes
