10 Sep 2024 03:16 PM
The multiroom box needs to be reconnected each time it's used but it still has poor performance with picture quality when in use. The WiFi signal is strong by the main box and the multiroom box.
10 Sep 2024 03:24 PM
Posted by a Superuser, not a Sky employee. Find out moreDoes Sky provide your broadband?
If not, Q to Q connectivity doesn't use your broadband not matter how good/fast it is.
10 Sep 2024 03:25 PM - last edited: 10 Sep 2024 03:26 PM
Hi @ABAa1
Try completely resetting the mini.
First reboot the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
