Discussion topic: Sky Q minibus has started shutting down by itself
This message was authored by: Chelsea+mick
Message posted on 07 Sep 2025 09:36 AM
My minibus has started turning off and going unresponsive on a regular basis. The only temporary resolution I have found is a power off shutting down but it is starting to be a problem.
Find out more
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 07 Sep 2025 09:41 AM
Re: Sky Q minibus has started shutting down by itself
@Chelsea+mick Have you tried rebooting your main Q box ie
then
rebooting your mini box
Message posted on 07 Sep 2025 09:45 AM
Hi, Thanks for your message. Yes, I've done this but it keeps happening every couple of days which leads me to believe it's a more serious issue.
