Discussion topic: Sky Q minibox connection and pixelation issues
Message posted on 08 Nov 2023 11:41 AM
Hi, my sky Q mini-box (approx 6 years old) is struggling with recordings, keeps going offline and pixelating when playing back... how do I go about getting it replaced please?
Message posted on 08 Nov 2023 11:47 AM
Re: Sky Q minibox connection and pixelation issues
hi @MR+RICHARDS
Sounds more like a connection issue rather than the mini box.
Reboot the mini as above.
Failing all of the above it's time to contact Sky for an Engineer
