11
This discussion topic has been answered Discussion topic: Sky Q mini
This message was authored by: Mary63
Sky Q mini
Re: Sky Q mini
@Mary63 wrote:
Red light is now constantly displayed but sky box still won't turn on
Hi @Mary63
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Re: Sky Q mini
Hi @Mary63   Have you tried using the power button on the box itself, to rule out a problem with the remote. Any lights on the box?
Avatar for Mary63
Re: Sky Q mini
Box won't react to any inputs , no lights
Re: Sky Q mini
Hi @Mary63   Have you checked the fuse in the plug and the power cable is seated in the back of the box properly.
Avatar for Mary63
Re: Sky Q mini
I will check the fuse, power lead definitely properly inserted
Re: Sky Q mini
Hi @Mary63
Work through the following link.  There is reference to mini boxes
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Avatar for Mary63
Re: Sky Q mini
Re: Sky Q mini
Hi @Mary63
Avatar for Mary63
Re: Sky Q mini
Yes, red light is still constantly displayed and won't react to any input
This message was authored by: GeorgeC5
Re: Sky Q mini
One of my Mini Boxes would not work - the red light stayed on all the time. I held the RESET button at the back of the box down for at least 20 seconds and it started working again.
Avatar for Mary63
Re: Sky Q mini
No luck, thanks for suggestion
This message was authored by: catering
Re: Sky Q mini
i have tried every solution that was offered and i was promised a new sky box delivery today ? hasn't been ordered , i'm paying a lot of money for this box ? i had to go and buy a fire stick so my granddaughter can watch Disney in the bedroom when she stays over ..i'm so fed up now with it all its causing a lot of stress ,anger  and frustration this keeps happening to me and getting broken promises .old broken box is ready to be sent back to sky ,,,,
