Discussion topic: Sky Q mini
This message was authored by: RebeccaMc1981
Sky Q mini
Hi I have error code MR104 have reset box checked cables connected from main sky box and nothing!! This error code doesn't come up when you look at help guide does anyone know??
Re: Sky Q mini
Hi @RebeccaMc1981
It's a connectivity issue .
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Avatar for RebeccaMc1981
Re: Sky Q mini
Thank you will try they now
Re: Sky Q mini
That has worked thanks so much
