Discussion topic: Sky Q mini not working
Message posted on 25 Nov 2024 07:10 PM
Sky Q mini box is showing as working, its connected to Internet and main box, but any channel I pick all I get is a blue screen
Message posted on 25 Nov 2024 07:25 PM
Re: Sky Q mini not working
Hi @Gizmo11 First try rebooting the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
