Discussion topic: Sky Q mini boxes (x2) not working
Message posted on 08 Jan 2025 05:55 PM
Both of my sky Q mini boxes have suddenly stopped working. My main Sky Q box works ok. They both have power and within settings on my main TV it states the mini boxes are connected.
Message posted on 08 Jan 2025 06:30 PM
Re: Sky Q mini boxes (x2) not working
@GB39 Have you tried rebooting your main Q box ie
then
treboot each mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 08 Jan 2025 07:05 PM
Hi @GB39
Try a Network Reset on the minis. Start with the one nearest to the main Q box
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Message posted on 08 Jan 2025 08:50 PM
Thank you both. I am now sorted, much appreciated.
