Discussion topic: Sky Q mini box
This message was authored by: TD65
Sky Q mini box
My mini box is all loaded and displays menu but when I select channel it says program unavailable. I can access apps and watch apps but not channels?
Re: Sky Q mini box
@TD65
Providing you're not trying to view a UHD channel on your mini box (which you can't do) it's worth starting with a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
▪️I AM NOT A SKY EMPLOYEE ▪️
