18
This discussion topic has been answered Discussion topic: Sky Q mini box
This message was authored by: DJourn63
Sky Q mini box
Hi
both my sky Q mini boxes have an error
please check your subscription entities you to watch this channel
it will not allow you to watch any channels
thanks
This message was authored by: Brill+Gill Answer
Re: Sky Q mini box
Posted by a Sky employee
Hi @Chodley, thanks for escalating this. We’ve sent @DJourn63 an invite to chat.
Please be aware conversations automatically close if there is no response within 48 hours.
Re: Sky Q mini box
@DJourn63
Which channel (s)?
Are you trying to watch in UHD?
Avatar for DJourn63
Level 2 icon
Re: Sky Q mini box
You cannot watch any channels not even bbc
Re: Sky Q mini box
@DJourn63 wrote:
Hi
thanks
Hi @DJourn63
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini).
Avatar for DJourn63
Level 2 icon
Re: Sky Q mini box
Hi
Both mini boxes are connected to the network
Re: Sky Q mini box
@DJourn63 wrote:
Hi
Connected to what Network  @DJourn63 ?
Also who is  your broadband supplier?
Avatar for DJourn63
Level 2 icon
Re: Sky Q mini box
Sorry connected to the internet and sky is the provider
Re: Sky Q mini box
Yes @DJourn63
 but it would appear that they are not connected to the main Q box.
That's why it is necessary to complete the procedure I outlined in my post.
Avatar for DJourn63
Level 2 icon
Re: Sky Q mini box
Ok I'll try now
Avatar for DJourn63
Level 2 icon
Re: Sky Q mini box
Reset all
sky Q main box is working fine
sky Q mini says it is connected to sky Q box and the internet
Still has the same fault
please check your subscription entitles you to view this channel on this box
will not let you view any channels
thanks
Re: Sky Q mini box
@DJourn63 wrote:
Reset all
thanks
hi @DJourn63
Did you carry out a Network reset on each mini and connect them to the main Q box using WPS?
Avatar for DJourn63
Level 2 icon
Re: Sky Q mini box
No but will try
Avatar for DJourn63
Level 2 icon
Re: Sky Q mini box
Hi
reset by wps
sky mini still has same error
on all channels
Avatar for DJourn63
Level 2 icon
Re: Sky Q mini box
Any solutions
thanks
Re: Sky Q mini box
Does sky go work?
