3
This discussion topic has been answered Discussion topic: Sky Q mini box
This message was authored by: Paul56308
Sky Q mini box
I have just had a Sky Q box installed. Am I entitled to a mini box to connect to the telly in the bedroom? Thanks.
This message was authored by: nigea99 Answer
Re: Sky Q mini box
@Paul56308 wrote:
Thanks @nigea99 .
I can't afford the multiroom subscription tbh. I'm already paying enough for my subscription I think.
Thanks anyway.
Unfortunately the multiroom does ramp up the cost and not everyone can afford it or otherwise find it cost effective.
Re: Sky Q mini box
hi @Paul56308
To use any minis you need the monthly multirrom subscription.
There is also usually a one off  admin fee for each  mini - although it is often waived for the 1st one
BTW  you can use a maximum of 2 minis at the same time for SKY content - Satellite/Recordings- (only one if you have the non UHD box - Hardware version 32Cxxx) although you can have up to 4 on the account
You may be able to use more at the same time if the first ones in use are only being used for Streaming apps such as Netflix or Disney+
Avatar for Paul56308
Re: Sky Q mini box
Thanks @nigea99 .
Thanks anyway.
Re: Sky Q mini box
@Paul56308 wrote:
Thanks @nigea99 .
Thanks anyway.
