Discussion topic: Sky Q mini box
This message was authored by: Smurf501
Sky Q mini box
I've had a Sky main box and mini box for years and have had no real issues.  I recently had a news wireless router (not Sky) and have had issues since. Main Sky box is ok but mini box isn't working at all today (1st August). I'm a wheelchair user and done everything I can but made no difference. Rebooted both boxes. Yesterday mini box worked after alot of messing around.
Re: Sky Q mini box
Hi @Smurf501
Reboot the mini as above.
Avatar for Smurf501
Re: Sky Q mini box
