Discussion topic: Sky Q mini box
This message was authored by: Margaret19450
Sky Q mini box
My sky Q mini box upstairs keeps freezing.  This happens when watching live tv or recorded. Could this be an issue with the router as this is downstairs. It does show as being connected when I look on the settings.
Re: Sky Q mini box
Hi @Margaret19450
if you are on Sky Broadband then your mini can connect by WiFi to your router.
However if you are on 3rd party broadband then the Q box must use the WiFi from the main Q box.
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Avatar for Margaret19450
Re: Sky Q mini box
Thank you, I am with sky for my broadband and I have tried all the suggestions. I have had the mini box for a few years, however late last year I got an updated router. It seems that the Wi-Fi is weaker now upstairs for some reason.
Re: Sky Q mini box
Is the router nearer to the mini than the main q box @Margaret19450 ?
Re: Sky Q mini box
No the mini box is upstairs and the router and main sky Q box are downstairs
Re: Sky Q mini box
Yes understood @Margaret19450
But which is closest to the mini?
Re: Sky Q mini box
The router is in the room underneath where the mini box is.  The sky Q box is in the next room to the router.
Re: Sky Q mini box
So Assume you have carried out a Network reset on the mini and then pressed the WPS button on the router?
If this hasn't connected the mini successfully then you may need a Q booster positioned somewhere convenient between the router and the mini.
Re: Sky Q mini box
Yes carried out a reset. Where can I can a q booster from?
Re: Sky Q mini box
Hi @Margaret19450
Sky will supply you with one.
They should be free of charge to aid Q connectivity issues
Re: Sky Q mini box
Thank you so much. Sorry for the blunt replies, I am not very good on the tablet.
