Discussion topic: Sky Q mini box x3
Message posted on 27 Mar 2026 07:48 PM
Sky Q mini box x3
Hi , i recently had to upgrade to a 2TB Sky Q main box so I was able to stream all 3 of my Sky Q mini boxes .. (or so I was told 🙄) ... I still have the same problem ! .. I can only have 2 mini boxes on at once , it says I have reached the maximum amount allowed and it won't let me view anything on my 3rd box 😐 .. Am I missing something here ?? .. slowly losing the will !
Message posted on 27 Mar 2026 07:50 PM
Re: Sky Q mini box x3
@Shonacraig77
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+. It’s worth mentioning that UHD content can’t be viewed on a mini box.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
Message posted on 27 Mar 2026 07:55 PM
Hi Daniel
Thank you for that information. I just read there that you can watch all 3 mini boxes simultaneously if the main box tv is off. It's definitely the 2TB box i have. I suppose I'll just have to stick with Netflix at bedtime then when the kids have their tv's on (age 16 and 22)
Message posted on 27 Mar 2026 08:03 PM
@Shonacraig77 wrote:
Hi Daniel
Unfortunately the limit, as detailed by @Daniel0210 is two (for SKY Content)
As @Daniel0210 also mentioned you may be able to use 3 if the 1st one in use is only being used for streaming apps like Netflix, Disney, etc
The limit does not change whether the main box is on or not.
Message posted on 31 Mar 2026 04:23 PM
Thank you 😊 ..
