Discussion topic: Sky Q mini box - tv guide yes, selection no
This message was authored by: ES98
Mini box linked to main Q box.  TV Guide available but selecting a channel results in a blue screen with no sound.  Mini box software updated 2 weeks ago.  Link to Q box reactivated.  No improvement.  HDMI cable changed.  TV picture and sound fine on aerial cable.  I think the mini box is faulty.  Any suggestions?
Re: Sky Q mini box - tv guide yes, selection no
Hi @ES98
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Avatar for ES98
Hi oldfella,
Thank you for your suggestions and instructions which I am delighted to say resolved the problems with my Sky minibox.
