Discussion topic: Sky Q mini box running hot
This message was authored by: C16bro
Message posted on 18 Mar 2023 11:00 AM
Our main Sky Q box is cool to the touch, but the mini is too hot to touch at all times. I've tried resetting, restarting but nothing fixes this problem It works without issue but is a risk due to its constant heat issues. Any suggestion on solving the issue? thanks
Find out more
Message posted on 18 Mar 2023 11:05 AM - last edited: 18 Mar 2023 11:06 AM
Re: Sky Q mini box running hot
Presuming that the mini box is in a well ventilated position it should always be cool enough that you can rest your hand on the top. You may need to contact Sky and get it swoped.
https://www.sky.com/help/articles/sky-q-boxes-are-warm-to-touch-or-noisy
▪️I AM NOT A SKY EMPLOYEE ▪️
