2
This discussion topic has been answered Discussion topic: Sky Q mini box recordings please wait
This message was authored by: basilfaulty
My Sky Q mini box has had recordings "please wait" all day today. The main box is working fine and the connection between them seems fine.
Re: Sky Q mini box recordings please wait
Hi @basilfaulty
Reboot the mini as above.
Hi @basilfaulty
Avatar for basilfaulty
Level 2 icon
Thanks that has sorted the problem.
