Discussion topic: Sky Q mini box pixelating
Message posted on 30 Nov 2025 09:28 PM
When watching recordings on our mini box upstairs, we frequently suffer pixelation. How can we solve this please?
Message posted on 30 Nov 2025 10:01 PM
Re: Sky Q mini box pixelating
Hi @Raywell
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
