Discussion topic: Sky Q mini box not working
Message posted on 30 Aug 2023 06:18 PM
Sky Q mini box isn't working.
It has the home menu with the pictures and I can scroll through the menu options but have no picture.
i have reset the box completely twice and linked it to the main box each time. The settings menu says that it's connected to the Sky Q box and there is a network connection.
Any ideas as to what to do?
Message posted on 30 Aug 2023 06:22 PM
Re: Sky Q mini box not working
Hi @Lance20
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Message posted on 30 Aug 2023 06:31 PM
Thanks. I've tried all that and still have the same issue.
