Discussion topic: Sky Q mini box non responsive
Message posted on 05 Aug 2023 08:28 PM
Mini box will not turn on only red light remote has no effect turning off resetting box has no effect cannot get green or orange light
Message posted on 05 Aug 2023 09:47 PM
Re: Sky Q mini box non responsive
Hi @Dr+Duncan
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 06 Aug 2023 11:09 AM
Thanks but I fear the box is dead
no response to anything
Message posted on 06 Aug 2023 11:23 AM
Hi @Dr+Duncan
Message posted on 07 Aug 2023 08:11 AM
ThankThe mini box is unresponsive & I think dead
