Discussion topic: Sky Q mini box issue
This message was authored by: JamieR1
My sky Q mini box won't let me do anything or connect to the internet, it just comes up with accessibility settings but won't let me press anything
Re: Sky Q mini box issue
@JamieR1 try the following...
Unpair the Sky Q remote from the box by holding 4&6
Wait for the remote to flash you should then be able to dismiss the information screen by clicking on Skip & set up later
Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control your TV.
