22 Jan 2024 04:00 PM
My sky q mini box is not working it says that there is no Internet and that the box isn't available I have tried restarting my router and connecting, re activating the box , unplugging it for 1 hour, also tried manually connecting using WiFi name and Password
22 Jan 2024 04:51 PM
Hi @Munetsi
Reboot the mini as above.
