Discussion topic: Sky Q mini box freezing
This message was authored by: dontknow123
Sky Q mini box keeps freezing. Turned it on and off may times problem still there. Robot totally useless. Is there any phone numbers where you can speak to real person
Re: Sky Q mini box freezing
Hi @dontknow123
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and see if an Agent responds.
https://www.sky.com/help/home
Regarding your issue
Reboot the mini as above.
Avatar for dontknow123
Thanks I will try these things if it does again rebooted main skyQ box and reconnected wifi to sky mini .will see if it's any better thanks again for the information. that robot is very frustrating
