Discussion topic: Sky Q mini box does not function correctly
Message posted on 23 Sep 2026 02:35 PM
We have 2 mini boxes. one in the second lounge is not working. We cannot rewind recordings. Some times we cannot even get the sky on our TV we have to watch main TV programmes no sky
Message posted on 23 Sep 2026 02:57 PM
Re: Sky Q mini box does not function correctly
@Sky+downgrade
It’s always worth starting with a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
If that doesn't work try rebooting your broadband first - then the above.
