Discussion topic: Sky Q mini box - Different networks
This message was authored by: Ashley1
Hi,
Does my Sky Q mini box need to be on the same network at my main Q box? I'm trying to set up Sky & broadband in two households and I'm unsure if the multi room package will work.
Re: Sky Q mini box - Different networks
Yes it does, both technically and to be compliant with the contract T&Cs.
@Ashley1 wrote:
Hi,
@Ashley1 If you mean can you have your Sky Q Main Box in one house and the Sky Q Mini Box in a different house, no you can't.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Avatar for Ashley1
Level 0 icon
Hi @oj01, yes that is what I meant, thank you for confirming
Sky sold me the mutli room option and I had a feeling this wouldn't work
Ashley
Multiscreen is supplied in anticipation of a 'normal' domestic single-household internet/network setup: splitting a Mini from its main box isn't possible under the terms of the subscription and so has never been supported technically.
