Discussion topic: Sky Q mini WiFi connection query 007
Message posted on 29 Mar 2025 08:53 AM
Does Sky Q mini get it Wi-Fi from the Main Sky Q box or the nearest Wi Fi access point?
Main Sky is connected fine via WiFi not Sky BB and one Mini is fine . Another Sky mini is closer whilst it is saying connected etc no picture I tried all the resets and restarts
Message posted on 29 Mar 2025 10:59 AM - last edited: 29 Mar 2025 11:07 AM
Re: Sky Q mini WiFi connection query 007
Hi @ATC7
On 3rd party broadband Q minis if using WiFi will only connect to the main Q box or a Sky Q booster.
edit
You can also connect to an already connected mini.
Message posted on 29 Mar 2025 11:06 AM
Try the following @ATC7
Reboot the minis as above.
. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Message posted on 29 Mar 2025 11:48 AM
Thanks I will try this next week as away for the weekend.
thanks again
