Discussion topic: Sky Q keeps losing internet connection
Message posted on 05 Sep 2025 08:28 AM
Was sent a new sky router about a month ago when I renewed my sky broadband package. Since then my sky Q box (and mini boxes) keep losing internet connectivity after about 5 minutes. I've tried everything and followed all the recommendations on different forums. The last router (the black one) worked fine. Can I not just have that back???
Message posted on 05 Sep 2025 09:21 AM
Re: Sky Q keeps losing internet connection
- It's not your hub it SKY there is a problem with the network which should be fixed in a couple of days if not sooner, I have had the same problem this morning.
Message posted on 05 Sep 2025 04:59 PM
@Dan227 The new white max router works differently to how the black router works.
The white router doesn't join your mesh as the black did so you need to connect your main box to the white router by treating it as a third party router and any mini boxes need connecting direct to you main Q box by way of the WPS button
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 06 Sep 2025 05:33 PM
This seems unlikely. The new router from Sky works differently from the old one and this problem is very common.
Message posted on 07 Sep 2025 04:33 PM
It's a problem for me too. It can work for a few days then the internet drops out every few hours.
Unplugged the box & it worked for a few days but back this afternoon, I've also reset the router.
I wonder if there's been a Sky Q update recently which is corrupted/faulty?
I don’t work for Sky.
If I have helped then please leave a like.
Message posted on 07 Sep 2025 10:42 PM
No it's been flakey since forever and there haven't been any recent updates.
Message posted on 08 Sep 2025 11:48 AM
In our case it's just started - about 4-6 weeks ago, hence why I thought it might be an update.
Message posted on 08 Sep 2025 02:57 PM
@twilight+princess wrote:In our case it's just started - about 4-6 weeks ago, hence why I thought it might be an update.
Just finally got in the boat with the rest of us 😁
Which ISP?
Message posted on 08 Sep 2025 06:14 PM
Yep. 🙂
Virginmedia. I've restarted the router.
