Discussion topic: Sky Q keeps freezing
Message posted on 14 Feb 2026 09:46 AM
Tv sound on, sky Q screen stuck/frozen and remote doesn't work.
Have to turn off and on again at power point....
happening too regularly, help
Message posted on 14 Feb 2026 11:53 AM
Re: Sky Q keeps freezing
@RavenA wrote:
Tv sound on, sky Q screen stuck/frozen and remote doesn't work.Have to turn off and on again at power point....
Hi @RavenA
Message posted on 15 Feb 2026 01:30 PM
Was happening to ours and our software wouldn't update. Called Sky they are sending a replacement box as ours was old.
