Discussion topic: Sky Q hdmi output error on main box
This message was authored by: Tadleyian5
My sky Q main box has errors with the hdmi output, have replaced the hdmi cable no change , have
used a spare tv and same issue,
 each time have. To remove power to the box and reset the sky q it the functions until tv turned off the have to. Reboot very painful.
i have tried to contact the sky Q troubleshooting team. But only get sent round and round.
sky help has died robot is rubbish.
Re: Sky Q hdmi output error on main box
Hi @Tadleyian5
